Friends -
We are about to install water meters. We are likely to purchase the Minol Minomess 130 Residential Water Meter:
http://www.buygpi.com/minol-for-hot-and-cold-water-service-includes-reed-switch-pulser-and-0.aspx
We like the idea of the pulse counter (the digital read out) mounted on the side of the house for easy reading, while the tamper-proof analog meter remains in-line under the house and away from the cold as a backup to be read.
What do you use and why?
Thank you,
-jl-
Jefferson,
I prefer Metron-Farnier Spectrum 30 Meter with the Innov8 Register.
They have a built in wireless transmitter sort of like a MasterMeter’s FAM Line.
The difference being is that these meters fit in a Meter Jacket thus making them
easier to insulate and keep from freezing.
Also, the only moving parts are the offset impeller. Otherwise the movements are
picked up by a sensor and not a magnet, thus making your low-flow loss numbers
almost non-existent.
All in all they are a great product.
Noel_S
January 21, 2014, 9:03pm
3
Which one did you end up going with Jefferson? How did it work out?
CCon
July 13, 2015, 5:30pm
4
Hi HarrisonKjellABT,
What price range did you get your meter setup for?
