I was looking at a few properties last night and I realized that I might not have a clear understanding as to how to value park owned home revenue and I wanted to get input on the correct way to do it.
I understand that an accepted method to value the revenue from park owned homes is to take the difference between the lot rent and the park owned home rent
So if POH rent is $500 and lot rent is $200…the value you would assign to the park owned home revenue is $300.
The piece that I am having trouble understanding is the gross rent multiplier…From what I understand depending on the condition of the park owned homes you multiply the difference between POH & lot rent (total annual revenue) by the GRM and that give you the amount you would be willing to pay for those POHs.
Say you had a park with 40 lots (20 POH, 20 TOH) with the same rents as above and it’s a 7 cap market with a 30% expense ratio…let’s say the GRM for this area is 2.
20 TOHs @ $200 = $48,000 rev/yr
20 POHs @ $300 = $72,000 rev/yr
How would you value this park? Do you cap the $48k+72k?
48k+72k =120k x .7= 84,000 / .07 = $1,200,000 purchase price
Or…do you cap it on straight lot rent revenue for the whole park and then add back the value of POH using the GRM…$200/m for all 40 lots…$96,000 annual revenue x .7 = $67,200 / .07 = $960,000 purchase price on lot rent only
Then once you have the $960,000 purchase price do you add back in the POH value based on the GRM (72,000 x 2 = $144,000)
Purchase price of $960k + $144k = $1,104,000
Using a GRM of 2 this would say the 20 POHs are worth $7200 each…i know the value depends on the condition of the homes but I just want to make sure I am thinking about this correctly and not double counting revenue
