I’m curious if others in SE are seeing exurban costs to mobile homes. In N. Florida the prices are stupid. I own a 26 unit park and in updating the park I spent 4 weeks finding one. Of the 5 movers in the area who would even call back. He gave me a price of $8700 EACH to move 54’
‘ and 64’ (1980’s ) single wides 500 feet - within my own park. So based on my other park experience - the cost (6 bids) to demo a single wide was $5500 -$8900.
I’m readying and hearing $2000 - $4000 to move and set up homes. The only bid I could get (after 2 months - 4 movers) for a double wide - 1999 - moved 13 miles was ……$21,800. Just stupid. Of course, we did nothing.
Seems insane….I’m going to end up setting up a MH moving company at these prices.
The cost of moving in the Southern United States can vary based on several factors, including the distance of the move, the volume of items being transported, additional services required, and the specific moving company chosen. To provide you with a more accurate estimate, it’s recommended to request quotes from moving companies directly, as they can take these factors into account.
On average, local moves within the same state might cost anywhere from a few hundred to a couple of thousand dollars, depending on the size of your home and the services needed. For long-distance moves, especially if you’re moving across state lines, costs can range from a few thousand to several thousand dollars.
Factors influencing moving costs in the Southern US:
1. Distance: Longer distances generally result in higher moving costs. 2. Home Size: The larger your home, the more items there are to move, and this can impact the overall cost.
3. Additional Services: If you require additional services such as packing, unpacking, storage, or special handling for valuable items, these can add to the total cost.
4. Timing: Moving during peak seasons or weekends might be more expensive than moving during off-peak times.
5. Company Reputation: Established and reputable moving companies may charge higher rates for their services.
It’s advisable to obtain quotes from multiple moving companies and be sure to discuss all the details of your move to get accurate estimates. Additionally, inquire about any potential extra fees or charges that may apply.
I can understand why those numbers seem high, especially for a move of only a few hundred feet within the same park. One thing that may explain the difference is that mobile-home moves can involve much more than the actual transport, including disconnecting utilities, permits, site access, leveling, tie-downs, and setup. Double-wides can also require the sections to be separated and reassembled.
Please break down the quotes into transport, permits, setup, and other fees. That would make it easier to tell whether the market rate is actually high or whether some of the individual services are driving up the total. The prices mentioned by others in the thread also show how much the cost can vary by location and job.
