Septic overflow and POH due diligence
Hi all, I have a bit of a story to tell…
I purchased a park a little over a month ago. The park has 32 homes of which half are park owned. Utilities are city water (not submetered) and private septic (tanks/fields). Generally, it’s a 2:1 ratio of trailers to fields, save for a few on the ends of the parks. During my due diligence process, I had a phase 1 study completed, a contractor to check the water lines, and also had the county come out to do an evaluation of the septic fields. However, I did not have anyone go into each of the park-owned homes to inspect them as the seller did not want the tenants to know of the pending sale…and since this is my first purchase, wasn’t sure if that was even appropriate to require as part of the transaction (lesson learned maybe?) None of the assessments came back negative in any way, all said the utilities and their systems appear to be in good working order, although it’s a 40 plus year old park, so no guarantee with anything. I also assessed the previous work done on the septics (invoices) but nothing appeared out of the ordinary…just the usual pump outs which I attributed to maintenance.
A few days after my purchase, I received a call from a tenant regarding septic backup in one of our park owned homes. We had a contractor go out there to check and he pumped out the septic tank but said the drain field is on its last legs and would need to be replaced. Just to be sure, we had another contractor come out and he came to the same conclusion.
Things appeared to be fine but they had an unusual amount of rain, which obviously started to fill the drain field again, causing further issues and also delayed the county from being able to go out there to permit the work. A week or so after, the county was able to permit the septic field to a more distant location because there wasn’t any space around the trailer for a drain field.
Because of the rain, I had the septic tank pumped out one more time as it was clearly not being able to accommodate the rain and septic use. Earlier this week, my tenants in the POH that were dealing with the issues shared pictures of the tub being flooded with septic water. As a courtesy, I placed them in a hotel for the past few days until the contractor could complete the work.
The septic contractor came out and installed the drain field, but on Friday noticed there was a large puddle of water underneath the POH, to which it appeared to still be leaking. The tenants were still in the hotel so he assumed it was fresh water.
A plumber came out there and turned the water back on to see where the leak was coming from but noticed nothing was leaking. So he went under the home and opened up the insulation to find significant amounts of sewage within the insulation. He then went into the home and it was filled with an inch or two of septic water. From what he told me, it appeared that the stop valve for the toilet was not working, which as a perfect storm, occurred simultaneously with the septic drain field not draining. As a result, the water from the toilet was continuously overflowing onto the floor.
The plumber recommended a remediation company, and he came out and gave his analysis, which was that this was in extremely bad shape, the water was an inch deep everywhere, there were holes already developing from the water, and because it isn’t fresh water, it is going to require an entire replacement of flooring, subflooring, probably walls, insulation, etc. as the damage is a “category 3.”
He said it would be upwards, minimum of $10k to just get it to the point of being able to reinstall the various fixtures, flooring, and ducts. That also doesn’t include possibly paying for any damages to the tenants belongings and getting the furnishings installed.
Temporarily, possibly permanently, I placed the tenants in a trailer that was just vacated.
Now my question is the following:
  1. I see two options now and wanted to get the forums thoughts:
  • “Gut” the trailer, i.e. remove the flooring (and subflooring), walls, and air ducts (as recommended by the remediation specialist), considering also the cost of installing new floors/wall/air ducts and the various furnishings (so basically starting with a carcass)
  • Demo the trailer altogether and bring in a new (used) trailer as a replacement, considering also the cost of demo, the cost of transport, and any additional remodeling that needs to be done?
Which option would be more advisable and obviously budget-friendly?
  1. My other question is regarding the due diligence process. Obviously, hindsight is 20/20 but this was not an expense I had assumed when I purchased the property, and so knowing that much of the issue is due to a faulty stop valve at the toilet that allowed the flushing to occur continuously, for future investments, how much effort should a buyer put into inspecting the interior of occupied park-owned homes?
Anyway, sorry for being so long-winded but I think context and transparency matters, even if mistakes were made on my end.
Appreciate any advice!!
Glad you had a vacated trailer to move them into, at least it keeps some rent coming in.
What’s the market for cash sale of trailers like in your area? If it’s not great, I’d probably go the remodel route.
A possible silver lining: if that water was running continuously over many years, that may have caused the field “failure”. Get that constant water infiltration stopped and you may find the field recovers, if even to buy a little time.
Don’t beat yourself up over the DD “miss”. You should do a walkthrough of every unit transferring over, yes, but even if you had, you still may have missed this!
It sounds like replacing the trailer may be more cost-effective in the long run, especially considering the extensive damage, but inspecting park-owned homes thoroughly during due diligence is crucial for future purchases.
Interesting- who would be responsible for the drain field repairs if this was a tenant owned home that caused the damage?
I’m about to buy a park with well and septic…
You own the systems. In theory you could hold tenants responsible. In reality if someone was even blatantly liable do you really think you’re going to collect $20k from them for a new drain field? I’ve had luck collecting $300 roto rooter bills over a month or two when they flush kids toys, diapers, etc but that’s about it. You own the system, gotta get it operating!
You make a great point about the continuously running water being a cause of the septic drain field failure. TBH, I had already completed the replacement before it crossed my mind. Which makes me think an annual inspection is a necessity for all park-owned homes.
Great question, but I doubt even if they were liable that I would be able to get the money from them. Half of my tenant base struggles as is with just normal rent payments.
I guess the whole point of this was just to hopefully help other owners watch for these sort of things…as crazy as it sounds, a faulty stop valve can lead to a failed septic field AND a potentially condemned trailer.
another good reason to install water meters immediately so you can monitor excessive water use. even if you are not charging them back.
I have 15 lots 3 TOH …I have two lots down do to septic concerns so I understand ALL the nightmares they can cause.
But the only reason I am replying is to say is …The state of PA you have to give tenants notice to sell.
What I see just happen to you is Karma …to keep the sale of the park a secret to the community is just wrong :cry:
Not to squabble but your comment about Karma for not disclosing the sale is actually extremely inappropriate and quite frankly, disgusting. The tenants were notified of the sale, once the due diligence period was completed, but not before. It was a requirement of the seller, not me, the buyer.
Regardless, your point of karma is just sad and says a lot about you as a person. I wouldn’t wish that upon you or anyone else so I wish you luck in your future endeavors.
I’m not sure if I sent a response back to your reply…
However I would like to apologize I hardly ever use it but it just kinda struck a nerve because the people in our park are really poor. I inherited the park it’s not been taken care of over the last several years as the owner had cancer for years. So when I saw the desperation in people’s eyes because we were gonna sell it it broke my heart. We ended up choosing not to sell it but I understand completely the issue you’re going through and with that I do feel bad because like I said we have 2 lots out of 15 with issues so yeah it’s a hassle believe me but I think you’ll really enjoy …t’s fun… will you be staying at the park and running it…
Again like I said I apologize I really do
When I replace a drain field, I have the contractor install a Y and two PVC ball valves.
I install a 24" HDPE pipe with a screw-on lid over the valves. You can leave a leach field offline for a few years, and it will recover.
24” Double Wall Corrugated Pipe, HDPE - 5’ Length | PlumbersStock
4" Y
Amazon.com
4" PVC ball valve
https://www.amazon.com/GASHER-Switch-Handle-Control-Valve(Thickening/dp/B0CM2YS8JL/ref=sr_1_5?dib=eyJ2IjoiMSJ9.fZA9c5QSjd3-H5Lz9-xtxpd-c_zNyzMcuxf5iRE97G-GATFIRegxmqLywh1sC2-H6Q4HFh1RRMT785YI-b-7q6C6zX2-B1bxXz4HsqRPkKS-oDDr-ZeAKjzCMdPFxHW0raC5hm84zNb1KreiqtURGu5X7vCsTpdgTMCLIZgXRcQxgvF5pCoL3azzPL5q5bdZXDIxvuPTGkj9NTGQI8A9BsSFpCMpP7YC4dAKNv-AZgY.EdsWYEuETh8tjnosh-7qug4qZT9Yk6cSwvOBRu7dYKI&dib_tag=se&keywords=4"%2Bpvc%2Bball%2Bvalve&qid=1744413388&sr=8-5&th=1
24" PolyLok Lid
https://www.amazon.com/Polylok-3008-West-Septic-Risers-Corrugated/dp/B00JEKKPNY/ref=sr_1_3?crid=2T7PIEJULUKAU&dib=eyJ2IjoiMSJ9.Hc0YSTglIynB9GvCdSztMqNihHSPs3uoCnG_7b_tF589087A_49tKR3834chaVXGeDd70reFcdTYzYHR4tYUCKcFrcYjZz93C-s9UbWyfldvViFySDaGjndyiZ9qyknqRkApCZ9IfJlZpUgnze9l8kHQxYMiRrTe3hvNNwA21ovC0B7XW9z2JSFeuovP6NRFSDPrYe2SsOwDwTMm5vDvCn5BGiqxDCL-oa2AalJ_rXE.pW1AtlOKHgGUgNgyFPvpXUK8H1kGh5e68ugRR_0CxY0&dib_tag=se&keywords=24"+hdpe+lid&qid=1744413419&sprefix=24+hdpe+lid%2Caps%2C174&sr=8-3
Another good tip is to Engrave a number on the lid and the spaces served by the leach field.
I also have a logbook of when we installed the new leach pit and its approximate location. In that log book, we also keep track of the dates we switch to a different leach pit.
Hi, I understand and I appreciate it. I’m in the same boat, and we have a lot of issues as well unfortunately. Not so much due to the prior owner being sick, but due to limited involvement and communication with the tenants which has led to some significant issues.
As a new owner, I had plans to address a number of issues to help create a better community but unfortunately, some of those have had to been pushed down the list of priorities due to a number of problems that should have been addressed by the previous owner. Some of these I had hoped would have been captured during due diligence, but I missed the mark in assessing the park owned homes prior to purchase and so my mistake is hopefully a lesson learned for everyone else here to make sure to require that homes be checked prior to any purchase.
That said, I appreciate the response.
Thank you! I may have missed this, but what do the Y and PVC Ball valves do for the septic field? I’ll definitely let me contractor know.
I wasn’t trying to be rude or cruel it’s just with a small park like mine the people are very poor actually and when we were going to sell I saw the desperation in their eyes and it broke my
heart quite frankly and that’s why we didn’t sell
So I apologize if it made it sound like I was being critical of you I just hit a nerve for me like I said because when we were going to sell and I saw the people’s eyes I just knew that it wasn’t the right thing to do but anyway I hope you come to a conclusion on what to do with that lot with the septic on it I find it Really weird how in the world is some of your Park City Water and some well and sewer That’s really different I never heard of it.
Again I didn’t mean anything mean it’s just I know you’re going through a rough time especially just purchasing it but you did the right thing buying…cause I’ll tell you what it’s fun and it’s enjoyable just take each day as it comes
The Y and the ball valves let you “rest” Leach Field “A” while Leach Field “B” is active.
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://actat.wvu.edu/files/d/a160b6d1-fc01-44f0-9b97-b04faac9c74a/nsfc-techoverview-altdrainfield.pdf
Alternating Septic Systems.pdf (1.1 MB)
What a shame… this happened to me with a drain field on my first park. Seller knew it was bad and I got stuck fixing it. Irritated me but I just rolled with it as I ‘needed’ the seller in my corner long term as I had seller financing and he lived next to the park. Anyways…
I would probably just gut the trailer and start in on it as a project rehab… piece by piece. Just my knee jerk opinion… not knowing all the details.
As for the septics what we have done is we installed Metron water meters to monitor water usage and we have the tanks pumped on a cycle every 4 years depening number of occupants. If we find inappropriate items in the tanks (grease, tennis balls fish tank rock, condoms, etc- all true by the way) we bill them for the tank pumping. Has happened several times and once word got out… things got better.
Sorry about what happened. Really is unfortunate but you will find your way through this and get everything back on track. These are the things we deal with in our business… good luck.
I was really looking for this thread. Few days ago I found similar type of info at another website.
Eeeesh, what a rough situation! Especially since you said it happened just a few days after you bought the park. I think if I had been in your situation, I would have chosen option #2, to demo the trailer and just bring in another trailer that I knew was in fine shape, whether it was new or used. I’d hate to gut it and fix it the best I can, and then later have trouble with it again. I’d just demo it.
What ended up happening? Do you have an update?
