Replacing Walk In Tub
Hi folks,
I need to have a bathroom in a 70’s single wide redone, including removal of a walk in tub and installation of an accessible shower. How much should I expect to pay, and best way to find a contractor who works on mobile homes?
There is such a wide range out there. Get a couple contractors out (which means calling 10-20+ if you can’t get referrals from folks in the park, because many won’t take the job). Random un licensed/insured guy in the park would probably do it for a couple grand. Real contractor you could easily be looking at 5-10,000.
I’ve been through the same thing; getting that walk-in tub out was such a relief. Definitely second-check with neighbors in the park. The mobile home part is key; make sure whoever you hire has experience with that specific setup, or you might run into surprises with the floor or wall construction. I found a resource like bathroom plumbing helpful when I was figuring out what to expect.
