Determining mobile home park’s value
Hi,
I have a general question regarding how to determine a rough value for a mobile home park on a per-lot basis. I understand that many factors contribute to a mobile home park’s worth.
For context, let’s assume the park has recently replaced its water infrastructure, which includes tenant services, tenant curb valves, new isolation valves, a new pressure release valve, and several new hydrants. The water and sewer services are publicly sourced. Additionally, the park is centrally located with access less than 1 mile to interstate highways. Park just installed 11 new security camera poles with new electrical service. Park is exceptionally clean, has paved roads, and maintains a 99% occupancy rate.
I’m only seeking an approximate per-lot value. For example, if a park has 50 lots priced at $40,000 per lot, that would give it a total value of $2 million.
I appreciate your input!
Thank you
What’s the lot rent?
$370 not including utilities. Rent is under market value and can be raised
You’re in the ballpark then, $30,000-50,000 per space isn’t crazy. Recommend actually raising rents to market to maximize your value though! Will do better than just putting that in the listing package
There is at least 1 other forum on hear where several folks have given formulas and methods to value a community. Take a look at those
