I have a lot that I’m considering moving a new 14x56 into with a gas furnace and stove. The lot currently has 60 amp power. Is there any reason to upgrade that to 100 amp?
Only if the electrician tells you to. Power is math, and the math of the amps the home draws will tell the electrician if the upgrade is essential. Could go either way. But I’m betting you have to go to 100amp.
