@AG , as per your post:
- “Has anyone ever used the window heating / AC units…?”
- “I have a 12 x 60 Mobile Home that needs a new furnace! I’m thinking of going with the window units!..”
- “The weather here can get real cold.”
We have 2 MHPs in South Carolina.
Our problem is more supplying air conditioning, but we also need to supply heat.
We have used the Window AC Units with Heat in approximately 3 of our smaller, older, renovated singlewide POHs (square footage=720 & 720 & 780). The rest of our POHs have new or newly installed HVAC units (with Heat Pumps).
Our Window AC Units with Heat have served us very well. We have had to replace 1 Window AC Unit with Heat thus far, but that is all the issues we have had.
We ordered our Window AC Units with Heat online from Home Depot for around $699.
Our Contractor installed a Special 230-Volt electrical outlet (will not work with a standard 115-Volt outlet). Our Contractor also installs a Wooden Stand outside to hold up the Window AC Unit with Heat.
We install ours in the actual window. However, the manufacturer states: “the slide-out chassis is designed for either window or wall installation”.
We have had these units for 4 Plus Years.
As per the manufacturer:
- “Median air conditioner with supplemental heat capability for a room up to 1,050 sq. ft.”
Now that square footage stated is probably for an open room. However, our window units with heat still provide enough heat for our Mobile Homes.
Since we are in a hotter region, we do install another Window Unit with AC only in another part of the Mobile Home (typically bedroom).
For our weather the Window Units with Heat work very well.
However, for colder climates I am not sure if they would provide enough Heat or be cost effective (for Tenant’s Electrical Bill).
Below is an example of the kind of Window Unit with Heat that we have purchased from Home Depot in the past.
We wish you the very best.
