Existing park homes longer than zoning allows
We own a park in Iowa. The park was built in the early 70’s. Lot’s are 40 wide by 80 long and were plotted out prior to the park being built.
The zoning requires there be 10 feet of space on the light to the front and rear of the home. Meaning the home can be no longer than 60 feet, but most of the homes that are in the park prior to purchase, majority of them are home from the 70’s are longer than 60 feet, sum up to 76 feet.
The city is not approving any homes longer than 60 feet according the the code that the park was under when built. Current code won’t allow it either.
Do I have any case against the city for not allowing longer homes since they have basically allowed it in the past?
Thank you for any help.
Adam
The burden of proof is on the property owner to demonstrate non-conforming status. If the 70’s code and current code both have your setbacks restricted, then you’re stuck with favorable setbacks only on the existing homes larger than that.
Contact an attorney to see if there are any precedents set for your state to the contrary.,…
It sounds like someone prior to you violated the code. Are you being required to remove those homes?
To answer your question, no, you don’t have any case against the city. Can you place the homes diagonally?
#4
We are not being required to move the homes and no they won’t fit diagonally as well.
Thank you.
