Any Thoughts on AI in MHP space?
FYI, I’m building AI tools in the MHP space and previously worked in the MHP space as a community manager and also as an ops person. I’m not selling anything here. I’m genuinely interested in hearing what others are seeing in the field.
Is anyone currently using AI in their leasing or operations stack and seeing measurable NOI improvement?
I’ve spoken with a few consultants in the space, and they mentioned that AI adoption is definitely happening, but some operators are starting to pull back because the results haven’t matched what was promised.
I’m working with a 1700-lot operator, and we’re working together now to see what the best places to start are and decided to start with meter-swap workflow and prospect call handling. Curious to hear from operators, consultants, and vendors: where is AI actually working in MHP operations, and where is it still mostly hype?
We’re considering using AI for water meter usage spikes (to notify residents when there’s something that looks like a leak), and I suppose you could use AI to monitor your inbox for emails and texts coming in and create tasks in your tracker.
Good use case. We are also working on this for one of our clients on this workflow. However, I would like to point of lot of that integration doesn’t need too much AI unless it has the following features: making calls if they don’t respond to text, actually talking to the residents, and also following up with the property manager to escalate and keep track of the progress of the situation until it gets solved
The mgmt software we use for MHC and Res RE (Buildium)) is pushing ani options.
We have not used or considered
We built Lotly.ai which has the best AI features. There is an AI lot inspector, AI Leasing Agent, AI Maintenance agent, AI Support Agent, and a bunch of other features. It is the only property management software for mobile home parks built around AI. Mobile Home Park & Manufactured Housing Software Features | Lotly
