Does anyone have experience with installing tamper-proof (ie able to be locked) shut off valves on their natural gas meters? This seems like it slowly becoming a mandate from local regulators.
Quotes we’ve received for parts and labor are exorbitantly high, so I’m wondering if anyone has come up with a creative solution to make their existing valves lockable and tamper proof?
I would try something like this. If you drilled a hole on both sides the same size as the pipe, I think this would work. It is only plastic, so it will only keep a honest person honest.
Is this a requirement for an empty space? We are just required to have a cap or plug on the riser.
I bet you could make something with a hinge and some sheet metal
Good luck
