Question on 60/30 rule
Ron,
The 60/30 rule is based upon a 12 cap rate. Expenses usually run between 35% - 45% depending if utilities are billbacked to the tenant. Your expense ratio will be a lot higher if the vacancy is high. Your reserves will be dependent upon how old the infrastructure is at the MHP.
Corey
