We are being told by prospective managers and others that we are not paying enough for the management team. We are paying $10 per space plus credit for lot rent that comes to around $935 per month as recommended by administrators of this site. We have about 1/2 the homes that are park owned with lessee responsible for all repairs on NNN lease.
Here are the management teams duties for that pay:
Exhibit A. Assignment of Duties, and Addendum page
Daily Duties for Manager
1.Pick up trash around entire park and especially around Dumpsters
2.Check telephone messages
3.Check business mailbox for office mail
4.Advising owner of problems
5.Collecting and entering rents into computer park management software first 10 days
6.Sewer treatment plant; Daily make sure motor is working and waste is flowing; maybe have to add chemicals daily for a month or so.
7.Pump house cistern area: A. check pressure gages daily to make sure pressure on both gages is between 68-70 on both tanks B. Flowmeters: Make sure they are working
8.Make sure all park owned equipment is put away and all sheds are locked.
9.Make sure all the lights in the park are working
Weekly duties of manager
Weekly in the spring, summer and fall until too cold :
1.Mow the common areas weekly and the vacant lots also (but depends on how cold it is and how much grass grows , maybe ever two weeks)
2.Snow removal is only in winter months and only as needed
3.Tree trimming as needed
Monthly:
1.Meet with operator once a month
Annually:
1.Cisterns have to be cleaned with the pressure washers
2.Sewer Treatment Plant needs to be checked to see if sludge needs to be removed
General duties of manager
1.Meeting with potential residents
2.Filling out applications and leases
3.Titling with DMV
4.Filling out and delivering 3 and 5 day notices
5.Faxing notices and rental agreements to the attorney for evictions
6.Overseeing writs of possesslon
7.Managing repairs and maintenance
8.Mediating tenant disputes
8.Notifying tenants of rules violations
9.Reporting crime/emergency problems
10.Changing locks after eviction or move out
Manager will be responsible for all repairs to the park and park owned homes that are vacant. Manager will not be responsible for replacing anything that is a capital improvement. For example, things like replacing fences, seal coating, asphalt replacing, gator paving, crack filling, rehabbing a home for sale or lease option, sewer line replacing, water line replacing. Manager can do those things but will give us a bid just like any contractor based on their time and materials.
However, if it is a repair then that will fall under manager duties. For example, water line break, sewer line break and repair, sewer line clean out using our machine, water line break under the home (riser); broken couple of slats of fence
PARK OWNED MOBILES (Lease Option Homes)
1.Manage the make-ready of homes for sale/rent
2.Show homes
3.Lock / secure homes after showing. In the winter set temperature to 50 degrees. Convert home to gas if it is on propane.
4.Fill out applications and collect money order for Offer to Lease/Option/Rent
5.Answer calls from ads
6.Get all the paperwork signed by Optionee and collect all money needed for move in.
7.Conduct ââŹĹwalk-thruââŹÂ with new resident, give them the keys, and get Check In/Check Out sheet signed.
8.Inspect damage after move out for deposit refund
9.Make suggestions for advertising placement
- Truck. Tractor and all other park owned machines and etc : making sure all are serviced reg
Since we have 1/2 park owned homes should we be paying more per space to management team and how much?
thanks for your input
