@Brandon , as per your question concerning:
At one of our MHPs we were able to find a Licensed Electrician, who also works for the local Electric Company, to do our Service/Power Poles.
Our Licensed Electrician works after hours to do new meters and poles.
For our poles that are rotted at the ground our Licensed Electrician has replaced them with new poles.
For our poles that are leaning toward the Mobile Home our Licensed Electrician has replaced them with new poles also.
We have one pole that is right next to a gas line on a lot where we moved out an older, smaller Mobile Home and are in the process of replacing it with a newer, bigger Mobile Home.
Thus, the old pole needed to be removed and re-installed once the newer, bigger Mobile Home was setup.
Our Licensed Electrician was concerned about the proximity to the gas line.
Thus, he just cut the pole down so that there would be no interference with the gas line.
Once the newer, bigger Mobile Home is installed we will probably just have a new pole reset at the correct location based on the new size and location of the Mobile Home.
If you are removing or digging around your poles and you have gas lines in your MHP, I would suggest calling to get the lines painted before starting your work.
Also, be mindful of your water lines.
Hitting a water line is no fun.
We had a Mobile Home Mover hit a water line when setting up a Mobile Home and installing the hurricane mobile home tie down straps.
We wish you the very best!
